My average is about 16mpg including commute but no motorway and lots of hard addictive acceleration in 1st 3 gears whenever possible! Have had it as low as 11mpg average on a fast drive across Hartside Pass and probably single figures if the average was just taken on the way up!! 4th gear flat out acceleration to the red line on open sighted B Roads is so good - passenger almost went green!!Seem to remember some reports elsewhere about the remaining range indication being unreliable.
Given 72 litre tank = approx 15.8 gallons, 24 mpg would mean a nominal range of 380 miles. Engaging fun mode and dropping that to 15mpg would mean a 150 mile range.
Does that seem about right? Anyone getting lower than 15mpg away from the track?
Seems about spot on!! my average over 6500miles is 16.5,with as much as 31.5 on a very long run,and down to 7 around the yorkshire B roadsMy average is about 16mpg including commute but no motorway and lots of hard addictive acceleration in 1st 3 gears whenever possible! Have had it as low as 11mpg average on a fast drive across Hartside Pass and probably single figures if the average was just taken on the way up!! 4th gear flat out acceleration to the red line on open sighted B Roads is so good - passenger almost went green!!
Joe, how are you driving roads like Kanan and PCH while still getting that mileage. I think I'll be averaging single digits there!On my way back from mountain drives, I often fill up before returning the car. Once, I reset the trip computer and it showed 30.1mpg for the trip home. Well, I called "BS!" and went to fill up. After doing the math, the car had gotten 29.8mpg. I've since repeated this several times. It's truly a marvel.
