1 - 20 of 22 Posts
Always a cool down lap and always give the car a chance after a spirited drive, usually at least a couple of miles.
I'm paranoid about stuff like this. Probably I'm idling only 15-30 seconds though. Just enough to push some fluids around. Nothing specific in the manual, unless I missed it. Even under normal driving you'll notice the electric fans spin for 5 minutes or so after shutdown. Not sure why, maybe ambient temp more than hard running.
2 minutes cooldown is an unacceptable chore in daily driver role IMO. I let it breathe at 2000 rpms/6th gear when approach my house. AC off early too.
I've never seen the grey bars turn red, I'd definitely consider my options then. Can I trust the bars though?
Administrator
Discussion Starter · #6 ·
Gentlemen, Thanks for the input. I thought it was mentioned in the manual that a 2 minute cool down after track or hard driving was recommended. Agree that for a normal grocery run this is not a realistic option.
I am religious about giving the F40 a 2 minute cool down but those turbos are ancient tech vs. the 12C.
Maybe coking the bearings was more common when non-synthetic oils were in some cars ??? The manual only advises (p94) to cooldown if it was 'a high speed or high load run' ....... But who knows:confused:
I have always driven the last couple of miles at a steady pace for just such a reason,more a product of having it hammered in by my father,rather than reading that part of the manual!!
same here... always gentle when running home... however I have to say I have never, even on track seen the temperatures move up... and last time was high degree ambient heat at spa... (has it even been that hot there before... certainly can't happen that often!)
equally can't believe 6000 miles, four track days and no pads or tyres yet required.. monitor the situation closely, but still have plenty of life.. incredible really.. think tyres must be due to the fact that normally run in higher ambient and don't really go potty till the temps well into the 50c and then try and keep them at 70 ish.. certainly helps it would appear
I am a bit cruel on my tyres,third set after 13k,but my pads are only half worn? What does this say about my driving style ??????
I am a bit obsessive about this stuff, always leave the engine on idle for a while (30s-1min?) coming off the motorway or with any hard driving even though I would probably be off boost for a while prior to coming to a stop.
I worried when I first saw you post that- more about the tyres than your driving style ;)
I'm now at 7500miles and the tyres look to be in good shape. and my last few thousand miles wasn't a sedate pace....:rolleyes:
I had a 5 series BMW that blew the turbo at 15,000 miles because I never let it idle after my 140 mile motorway journey.......I repeated that trip for most of the 15,000 miles. Learnt a lesson but forgot it!
Another trick I often do on track days is to putting the heating on full during the cool down lap, it brings temps down pretty quickly. On my Aeromax you can watch the gauge drop, and of course this is manual intervention as opposed to waiting for the thermostat to kick in and start radiator fans.
The obvious issue with the 12c are turbos. They really need airflow to cool down.
I thought the whole letting the car run for 2 min procedure was for turbocharged cars running on Dino oil(non synthetic) - since it leaves broken down oil caked in the engine compartment. It shouldn't be an issue on modern engines with full synthetic oil. Another point: The fans run when the engine compartment is hot. Opening up the engine bay does a disservice since the fans might not run as long as they should. This is coming from my GT3 experience/manual. Porsche specifically advises against opening up the engine bay to cool down the car.
I still let the car run for 30 secs after a drive and do an extended cool down lap if I track the car.
Any need for an aftermarket turbo timer?
I know this suggestion may appear a bit 'ricey' for a modern high tech super car but those electronic gadgets were a fad in the past :eek::rolleyes:
love the fact you call them ricey,considering the part of the world you come from,quite funny how the whole world refers to certain things,but as Ritesh says it really is down to oil ,but old habits die hard,and it can only be beneficial to give it a cool down :)
You know RC33 that's a good question, I should get one of those installed, only if it doesn't void the warranty on the car. Cheers.....??
I just cool my jets when nearing home and drive the last mile or so gently. Frankly, unless you live on an off-ramp or have a house aside a race track (not impossible BTW), you will likely be averaging 30 mph on the last mile home if in a typical community, which works out to 2 minutes of gentle, off-boost and low rpm driving anyway.
You don't want to be an asshat like Bieber in the 'Hood.
1 - 20 of 22 Posts
