THE START. E85 1000hp 12c build - Page 2 - McLaren Life
 24Likes
post #16 of 69 Old 03-17-2019, 08:47 AM Thread Starter
12cKid's Avatar
Originally Posted by NVMcLaren View Post
Originally Posted by 12cKid View Post
Well 850HP Is about 720whp I’ve seen a 12c make 805whp and im running e85 so higher numbers won’t be to hard
What I mean is, McLaren put a 3.8 on a bench and kept cranking the boost to see where the limits are. At (whatever the boost level was I cant recall) the motor grenaded, and they backed the number to 850HP.
I haven’t heard of that yet but they were deff running 93oct or less ,e85 with 1300ccinjectors willhelp
current cars:
2013 12c 1000whp goal
2018 glc63 amg
1994 toyota soarer 1200whp
2014 audi r8
secret level 6 armored car
past cars:
2016 bmw i8
1998 RHD supra
2015 m4
2018 m3
2008 m3
2004 twin turbo gallardo
2013 gallardo 50th anniversary
2013 GTR
12cKid is online now
post #17 of 69 Old 03-17-2019, 11:10 AM
Yeah, they probably ran in to a detonation issue with the fuel at a certain boost pressure. You have to either lower the compression ratio or increase the octane - and if they indeed performed such a test, it would have been with the consumer in mind - i.e. regular gasoline. Also if they were just seeing what the M838T could do, they wouldn’t start changing internals to lower the compression ratio (already fairly low at 8.7:1).
Running on E85 should solve a lot of that (my 4-cylinder Evo develops over 700HP on E85).
12cKid - I would definitely recommend looking at adding water injection (WI) though for additional protection and for maintaining power. Also I’ve found that when air temps are hot, especially on standing starts where heat soak creeps in rapidly, WI makes a huge difference. In a back to back dyno test (which mimics a heat soaked engine since dyno cooling fans suck), I found that I lost about 12% of power - then turning on WI regained almost all that power. I typically like Aquamist for WI. Even BMW ships with WI on their stock M4GTS.
Z.
zerokewl is offline
post #18 of 69 Old 03-17-2019, 01:16 PM Thread Starter
12cKid's Avatar
Yes I’ve had WI on many cars , i won’t tune with it because if it fails while your running hard the engine could fail. But i have used it for heat soak
current cars:
2018 glc63 amg
2014 audi r8
past cars:
2016 bmw i8
1998 RHD supra
2015 m4
2018 m3
2008 m3
2013 GTR
post #19 of 69 Old 03-17-2019, 04:18 PM
2012 12C Coupe - VR
RonMathMD's Avatar
How about water-methanol injection? 50:50 mix. The Hypercar guys use it for their 800R builds and put down 776 whp reliably on the dyno with stock turbos. Weistec uses it too for their higher HP kits. I had w/m injection installed on my 12C before I sold it and IATs dropped 40-50 degrees when it was spraying. Worked great on a track day
2018 720S - Volcano Red
2012 Hyper800R 12C - Volcano Red. Sold but not forgotten.
RonMathMD is offline
post #20 of 69 Old 03-17-2019, 04:51 PM Thread Starter
12cKid's Avatar
With running 100% e85 it’s not necessary and if for some reason that meth pump fails with no fail safes set you will run lean and blow the motor. I’d rather run e85 or race fuel and get rid of that possibly of a meth pump or solenoid failing.
Kamran, RonMathMD, ima2nr and 1 others like this.
current cars:
2018 glc63 amg
2014 audi r8
past cars:
2016 bmw i8
1998 RHD supra
2015 m4
2018 m3
2008 m3
2013 GTR
post #21 of 69 Old 03-18-2019, 09:49 PM Thread Starter
12cKid's Avatar
PIC UPDATE!
Custom exhaust tip plates. Cost $300
Don’t know if I’m going to powder coat them black or not. What’s your thoughts?!
ZombiePhysicist likes this.
current cars:
2018 glc63 amg
2014 audi r8
past cars:
2016 bmw i8
1998 RHD supra
2015 m4
2018 m3
2008 m3
2013 GTR
post #22 of 69 Old 03-18-2019, 10:04 PM
DakotaGT's Avatar
PIC UPDATE!
Donít know if Iím going to powder coat them black or not. Whatís your thoughts?!
Looking good, but I would definitely powder coat them black.
dakota_gt on Instagram
DakotaGT is online now
post #23 of 69 Old 03-19-2019, 02:10 AM
definitely powdercoat
"Ut pallens nusquam"
@RES is offline
post #24 of 69 Old 03-19-2019, 06:00 PM
2012 12C Coupe - VR
RonMathMD's Avatar
I agree...
post #25 of 69 Old 03-19-2019, 08:13 PM
Looks great, why are you changing the fuel rails?
mdurbahn is offline
post #26 of 69 Old 03-20-2019, 12:39 AM
ima2nr's Avatar
PIC UPDATE!
no billet, chrome, or bling... Definitely paint them black.
BTW, they turned out great!
- 2012 McLaren MP4-12C Graphite Gray (his)
- 2012 McLaren MP4-12C Brilliant White (hers)
- 2016 Tesla P85d w/Insane Mode
ima2nr is offline
post #27 of 69 Old 03-20-2019, 03:02 PM Thread Starter
12cKid's Avatar
To add bigger fuel injectors!
current cars:
2018 glc63 amg
2014 audi r8
past cars:
2016 bmw i8
1998 RHD supra
2015 m4
2018 m3
2008 m3
2013 GTR
post #28 of 69 Old 03-20-2019, 03:02 PM Thread Starter
12cKid's Avatar
Originally Posted by ima2nr View Post
PIC UPDATE!
Thanks man!
current cars:
2018 glc63 amg
2014 audi r8
past cars:
2016 bmw i8
1998 RHD supra
2015 m4
2018 m3
2008 m3
2013 GTR
post #29 of 69 Old 03-21-2019, 05:30 PM Thread Starter
12cKid's Avatar
PIC UPDATE!!
Tips and down pipes done
Went with 3.5 pipes bottle necked to 3inch tips
current cars:
2018 glc63 amg
2014 audi r8
past cars:
2016 bmw i8
1998 RHD supra
2015 m4
2018 m3
2008 m3
2013 GTR
post #30 of 69 Old 03-21-2019, 07:59 PM
PIC UPDATE!!
You are putting heat shields on those downpipes right?
Z.
zerokewl is offline
THE START. E85 1000hp 12c build. 12cKid Mclaren News 0 03-05-2019 03:16 AM
Any e85 guys? mdurbahn McLaren MP4-12C 9 02-21-2019 03:44 AM
1000hp 375 Pirelli Monster - Corvette Z07 x ADV005 Track Spec CS by Wheels Boutique WheelsBoutique Other Road Cars (SLR, M6GT, M81) 0 07-14-2016 02:16 PM
Can you run E85(Ethanol) in the 12C? onefastturbo McLaren MP4-12C 5 05-08-2014 01:44 AM
1000hp P1? jkheit McLaren P1, F1 4 07-19-2013 05:45 PM
