Drivers Side AC Warm - McLaren Life
post #1 of 3 Old 05-14-2019, 05:08 AM Thread Starter
sld7007's Avatar
Ive got a 2019 with only 1,500 miles and the driver side AC is noticeably warmer than the passenger side. It is not as cold as it used to be. Does anyone else have this issue?
sld7007 is offline
post #2 of 3 Old 05-14-2019, 01:04 PM
McBroke's Avatar
It needs to be recalibrated... turn on A/C and then turn the fan blower to high then use the slider to turn the heat all the way up to hottest setting... run it like that until it gets HOT! Like 2-3 minutes. Return settings back to cold and you should have cold air blowing then.
McBroke is offline
post #3 of 3 Old 05-16-2019, 04:55 PM
Try to see if your coolant is between the two steps (- and +). Wait a couple hours until the engine is as cold as it can be and check the coolant level, it should be most accurate. Use a flashlight to see and top up if needed.
TwnTrbo is offline
Found Drivers side headlight defect [email protected] McLaren 720S 9 04-14-2019 05:07 PM
AC vent blows out air when AC is off? kareem650 McLaren 650S 0 02-27-2019 06:11 AM
Warm up your tires! Kutsuki McLaren 720S 6 04-23-2018 10:33 PM
What tire pressures are best cold/warm? noone2 McLaren MP4-12C 1 10-06-2016 04:41 PM
Warm start issue brambleworth McLaren MP4-12C 10 12-20-2014 10:40 PM
