Mk II Precision Hub Stands - McLaren Life
post #1 of 2 Old 04-06-2019, 09:46 PM Thread Starter
Colton-CSMPerformanceLLC's Avatar
We're very excited to be involved with the McLaren community. We engineer, design, and produce precision alignment tools in the USA. We've made products for customers ranging from Porsche Cup Cars to Radicals SR3s. So we'd like to introduce out main product as well as some of it's attachments:
Description
Here at CSM Performance LLC we are dedicated to making the foremost Hub Stands, if you want best you’ve come to the right place. Our Mk II Precision Hub Stands are unrivaled in weight capacity, versatility, accuracy, and finish quality. The best way to create a product is to go directly to the users and that’s exactly what we’ve done. The Mk II Precision Hub Stands have been designed with the help of racers, mechanics, and engineers using modern Finite Element Analysis tools to optimize every aspect. By mounting directly to the wheel bearing hub they ensure the highest accuracy possible. Followed by slashing your alignment times compared to other methods and even eliminate the need for strings when used with our specially designed Laser Thrust Alignment System (LTAS).
We offer an exact fit wheeled Pelican™ Case, the best cases in the world, to ensure easy transportation. We exclusively CNC machine our components from billet aircraft grade aluminum at an ISO 9001 facility right here in the USA. We’ve integrated our proprietary Lock-A-Lug system which employs tapered Lug Washers to perfectly match any pattern from 5x100mm (5×3.937″) all the way to 5x130mm (5×5.118″). Need a set for 5/8″ lug studs? We can precision drill and chamfer an addition pattern on the Hub Mount Plate, see options. Our Hub Stands take advantage of Ball Transfer technology to create a virtually frictionless surface for extremely precise alignment measurements. We have even included a positional locking system to hold the Mk II Hub Stands in place when needed. We’re able to do all of this and retain a fine height adjustment system to match practically any vehicle. We also include all the needed tools to assemble and utilize the Mk II Stands. Every tool proudly comes from a Made in USA sources including Proto® and Bondhus®. Each component flawlessly fits together; The Mk II Precision Hub Stands are a true blend of perfect form and incredible function.
Need Centerlocks or any other requirement? Give us a call or send us an email, we can do almost any custom work!
What’s Included:
Four (4) Mk II Precision Hub Stands w/ Toe Bars
Proto® Wrenches
Bondhus® Allen Wrench Set
Two (2) Tape Measures
Plus Selected Options
Links:
Home Page
LTAS In-Depth Overview
Pelican™ Exact Fit Case
Instructions
Please note, you may see photos of our older Original Precision Hub Stands floating around as well.
Colton-CSMPerformanceLLC is offline
post #2 of 2 Old 04-28-2019, 05:56 PM Thread Starter
Shipping out another set of Mk II Precision Hub Stands w/LTAS, Caster/Camber Gauge, and Pelican Case
Get yours today @: https://csmperformance.com/product/m...on-hub-stands/
And we've for a Subaru WRX on a set!
Colton @ CSM Performance LLC
https://csmperformance.com/home/
Brake hub damage after dealer wash Periokid McLaren MP4-12C 6 08-17-2015 10:38 PM
Putting the car on axle stands. Flynn McLaren MP4-12C 16 06-24-2015 03:34 PM
Specification Changes, What Stands Out? shmee150 McLaren MP4-12C 78 01-08-2014 11:31 AM
Hub Bore Size dronell90 McLaren MP4-12C 2 05-06-2013 12:19 PM
