Vinyl over or under Xpel? - McLaren Life
 1Likes
  • 1 Post By eMcL
post #1 of 10 Old 07-01-2016, 08:17 PM Thread Starter
MBG
MBG's Avatar
Getting a few parts of a car vinyl wrapped and am getting conflicting info on vinyl over/under the Xpel.
Case for over is that the vinyl can theoretically be removed if you want to change the look without removing the Xpel. Case for under is that the vinyl isn't as durable and doesn't self-heal like Xpel ultimate / will get chewed up over time.
Appreciate perspectives from those that have done this before.
MBG
MBG is offline
post #2 of 10 Old 07-02-2016, 10:40 AM
Recent Convert
mikey k's Avatar
I'm interested to hear some views on this as well
VR 650S Spider 14k miles done in 14 months!
mikey k is offline
post #3 of 10 Old 07-02-2016, 10:55 AM
nh4
nh4's Avatar
Hmm, that might just be a personal preference thing. I would probably go with vinyl under the Xpel if I was confident in the design I was doing with the vinyl. So long as you have good installers, the Xpel can be removed just as the vinyl, so there isn't much stopping you from going either way. One thing I would recommend asking your installer is how well the vinyl adheres to the Xpel over time. If I remember correctly, I think @ZombiePhysicist had vinyl over his Xpel when he did his around-the-US drive last year and the vinyl was a bit beat up by the time he was done.
-Jamie.
“I had nothing to offer anybody except my own confusion.” ― Jack Kerouac
nh4 is offline
post #4 of 10 Old 07-02-2016, 12:31 PM
I don't have vinyl on my cars but have seen an install.
If the job is "permanent" then you would want to apply the vinyl first to give the vinyl the Xpel protection from stone chipping. If the vinyl look is temporary then you would want to apply the vinyl over the Xpel for removal. The Xpel has a self healing property whereas vinyl which is much thinner does not.
It is not easy to apply Xpel over vinyl when the vinyl area to be covered is large. This is because the Xpel tends to "stick" to the vinyl surface and be difficult to adjust (move) over the vinyl during installation. The soapy water used during the install process sets up a thin slick surface over paint which then allows for some minor alignment adjustments. If the double covered area is small it is then much easier to place the Xpel in the correct position in one try and not require any movement over the vinyl. Best if you can find an installer that has done an Xpel over vinyl install already and has experience. You could also try calling Xpel help line and check if they can provide any help with Xpel over vinyl installs. But my guess is they will only give advice on Xpel over paint.
SSIIICK likes this.
eMcL is offline
post #5 of 10 Old 07-05-2016, 02:00 PM
MBG
We've had many people install the PPF first and then vinyl over the film. Many people do this for full-color changes and accent pieces for Rallys (goldRush Rally, Corsa, Gumball, etc etc.)
It comes down to preference, but from what we've seen its usually PPF then Vinyl
If the job is "permanent" then you would want to apply the vinyl first to give the vinyl the Xpel protection from stone chipping. If the vinyl look is temporary then you would want to apply the vinyl over the Xpel for removal. The Xpel has a self-healing property whereas vinyl which is much thinner does not.
We have installers that install PPF over the vinyl stripes on many vehicles (corvette, mustang, etc) and if removed properly, it should not remove the vinyl. There is always a chance it can remove the vinyl, but we'd recommend film installed first and then vinyl on top. Plenty of customers that do ULTIMATE, then Vinyl, also install a ceramic coating which helps prevent some minor swirl marks and makes cleaning a bit easier
XPEL Technologies Corp.
XPEL is offline
post #6 of 10 Old 07-05-2016, 02:07 PM Thread Starter
MBG
MBG's Avatar
Thanks Xpel. Any opinion on how well the vinyl holds up if it's on top of Xpel and it's on lower surfaces of the car, like side skirt/front lip/side intakes? It's those lower areas and the roof that I'm considering for a vinyl wrap.
MBG
Stay in school kids!
2012 McLaren MP4-12C, Standard Blue, HRE S204 (color matched)
2015 Lamborghini Huracan 610-4, Bianco Icarus / Nero Ade / Rosso Alala, FI Exhaust
2016 Infiniti QX80, a.k.a. "Tankamus" - will run over the McL or Lambo
Instagram: MBGCars
MBG is offline
post #7 of 10 Old 07-05-2016, 02:17 PM
MBG
It'll respond the same way as if it was on bare paint, although you have ease of mind knowing that once you remove the damaged vinyl you'll have your paint protection film there instead of rock chips in your paint.
Since vinyl is thinner and doesnt have self-healing properties, it's hard to say how well it will hold up...May be over kill but... PPF, Vinyl and then add an extra layer of ULTIMATE on the skirts, lip and intakes to help prevent removing and replacing the vinyl on a monthly basis
XPEL is offline
post #8 of 10 Old 07-05-2016, 02:43 PM
2012 MP4-12C
ZombiePhysicist's Avatar
-Jamie.
I had the 3M stuff over the Xpel. The Xpel held up great. After about 12000 miles, the 3M stuff started to disintegrate. You can see it here:
Zombie's (Fun and Fund) Around North America
ZombiePhysicist is offline
post #9 of 10 Old 07-05-2016, 04:08 PM
Ducati1199's Avatar
Just my 2c - I'd go over the top of Xpel every time. From experience I've had car Xpel'd, CQuartz and then vinyl applied and no issues with adhesion at all. I look at it in the light that the vinyl is another layer of protection for the car. Yes it does take a rock chip or two (depending on where it's placed on the car) but I'm guessing in most cases replacing the vinyl piece will be way cheaper than the Xpel piece. Generally you can't see the nick in the vinyl unless you're really looking for it and only the owner will be doing that. It can always be removed if you, or the new owner, doesn't like it. Or just if you want to change the color, pattern up every once in a while. And lastly if you apply Xpel or any PPF over the vinyl there's always a possibility of trapping air over the slightly raised surface of the vinyl. Small I know but could always be an area of weakness where the Xpel might start to lift at some time.
Ducati1199 is offline
post #10 of 10 Old 03-20-2017, 10:38 AM
Vinyl under Xpel will be a good choice if you don’t want to change the design but if you are willing to give your car a new look frequently then you should go for vinyl over Xpel. For my new car, definitely going to get vehicle wraps over Xpel soon.
Recer is offline
