#76 |
Wow! What an awesome opportunity.
2012 McLaren MP4-12C - 2011 Radical SR3 RS 2010 Rossion Q1-R Turbohoses 2010 Porsche Panamera Turbo Switzer P680 2010 Cadillac Escalade ESV Platinum 2006 Ford F350 Turbo Diesel Dually 1999 Mazda Spec Miata 1996 & 1989 Ford Mustang Chump Cars Team Leader |
#77 |
#78 |
Lawrence, thanks for the kind invite.
Unfortunately your advert doesn't actually say what date the Monaco GP is on!! Googled it anyway and your kind offer is now in my diary. Back to the original thrust of the thread and the Meridian system - the more I listen to it, the greater my disappointment. Not your fault, of course, but it falls well short of a premium ICE setup. My little Abarth sound better and the whole car was only three times what IRIS costs. My biggest gripe is that you need to adjust the balance for every track (not even album) that you play and my source material is top notch. Fingers crossed it is a software fix, although I now have my doubts. How can any bespoke system not handle all of the base that you throw at it. Surely any purpose designed system, especially at this level, should never distort when max base has been selected? Up above the streets and houses. |
#79 | |
Meridian are very much like McLaren and will want it to be perfect. Are you running non compressed files? |
#80 | |
Again, I know the system has potential because some of my music sounds incredibly good. But, is it so difficult to make a high fidelity system that can also dumb itself down to expand compressed files and make them sound great, too, just like on any other car stereo? |
#81 |
Last time I checked this was a 40w per channel system. All in the name of lightness I assume. All systems will reach a point of distortion, that is when you turn it down a notch. I have built 2,000w systems that are set to distort at max, if you don't hear the distortion level then you know you can go louder and you want the system levels set so you know.
#82 | |
Whilst I always rip to highest possible quality, i.e lossless or straight wav, many people like 6E have 256kbps files, particularly if they downloaded them from Apple and the system should be able to cater for the majority. Up above the streets and houses. |
#83 | |
New owner
My Classical test piece is Jacqueline du Pre playing Elgars Cello Concerto (EMI Classics recording) with the LSO. This has a broad range dynamically and with the purity of the single stringed instrument quickly shows up any lack of fidelity. Even this sounds immeasurably better with WAV. All of this still begs the question as to what size of storage will be in Doris when she eventually shows up. I fear that it may not be so big given that McLaren will have gone for the lowest weight option and this would be a Solid State Drive (SSD) rather than a conventional disk drive. Trouble is SSD's cost a lot more than disks of the same size, so it is unlikely to be huge. Anyway, I am happy enough with the SD cards for the moment and to be honest it is relatively unimportant compared with the pleasure of driving the car. All we need now is some better weather and even I can't blame that on McLaren.....
#84 | |
Sounds like I need to dig up a copy of Dark Side of the Moon; I will also look for your classical selection next time I visit the music store. I hadn't thought about the type of hard drive that IRIS will have. SSD might be preferable for its durability in a vibration-heavy setting and quick start-up time, too? |
#85 |
One thing to say is I sell high end home audio systems and it has always been the case of the better the system the worse it will make bad recordings sound.
So it will be rubbish in rubbish out I am afraid. Meridian make a system called Sooloos http://www.meridian-audio.com/sooloo...experience.php which is classed as the best music server on the planet. When we got it I started to put all my music on it including dragging my iTunes over to it. After listening to it I ended up deleting them as they sounded terrible although OK for back ground listening. The best format is the standard ripping format on the Sooloos which is Flac and these you struggle to hear the difference between that and CD. |
#86 | |
roundincircles Started with Scalextric Various 911's from 1991 MP12, Triumph Tiger Explorer 1200,BMW K1600 |
#87 |
As an experiment I tried playing FLAC and WAV files on IRIS via a memory stick. System didn’t recognise FLAC and sounded no different in WAV, when compared to my usual Apple lossless rips via iTouch.
The more I hear this system, the greater my disappointment. One track I played yesterday had rear bias set to 10 (max) and it still sounded front loaded. Up above the streets and houses. |
#88 | |
I own a numer of cars that I feed with Ipods. For instance my Audi S8 has a B&O system that sounds penomenal with my regular I pod and 256k files.
Also system in my Aston V8 Vantage is producing great solid bass even when listened very loudly. I set my system at high bass and high rear (as suggested by many here). But the result is still disappointing. BTW: Both settings are usually used on cheap, incapable systems to at least get somewhat reasonable sounds. If the speakers are good enough, it could be a simple amplifier issue. I am by no means an expert, but the sound system is a big weakness of the MP4-12C. Also, the FM reception quality is just HORRIBLE, DREADFUL, DISTORTED and traffic messages come in from anywhere, really UNUSABLE. And I can safely say that as I have various systems in various cars, driving through the same area, but this system is even worse than in my old 993 Porsche.... I still wonder, why there is no digital radio receiver available... So, if this system wants to be at par with the otherwise absolutely fantastic car, this needs some serious tweaking here. Quote:
#89 | |
In the meantime save them as WAV files |
#90 |
Owner Join Date: Apr 2011
Hi, having just received my car I am trying to establish the right way / format of putting music onto the very nice portable hard drive that McLaren London gave me. Most of my files are either FLAC or apple lossless (m4a). I seems that FLAC isn't supported but is m4a of suitable quality to get the best from the Meridian system?
Appreciate help. |
| Thread Tools | Search this Thread |
| Display Modes | |
