Replacement tires - McLaren Life
 4Likes
post #1 of 20 Old 05-12-2017, 07:46 PM Thread Starter
Replacement tires
what have u guys replaced tires with? I don't see the track but I like dry and wet traction on the roads down here in S Florida. DOnt need them yet but will.... wondering what other have found? Currently I have the P 0 CORSCA
Racer M is offline
post #2 of 20 Old 05-12-2017, 09:31 PM
isv
Has to be the new michelin PS4S.
Jtkeller and ZombiePhysicist like this.
isv is offline
post #3 of 20 Old 05-13-2017, 06:01 AM
broomhilda's Avatar
For the rough roads in my area I like my newly redesigned P Zeros
For track MPSC 2
It is better to exit a turn properly than enter too fast but with ABS just go deep anyway
MP4 12 C , Porsche 996 Cup factory racecar, Cadillac CTS Vee Wagon 700 bhp, manual transmission, Porsche 911 3.0 ltr racecar
broomhilda is offline
post #4 of 20 Old 05-13-2017, 03:40 PM Thread Starter
I am hearing the newly designed Pirelli P 0 Corsca on the 720s will be out shortly for purchase for the 650s?
I am also hearing the Michelin sport cup 2 are a bit squirrly on the 650....???
Racer M is offline
post #5 of 20 Old 05-13-2017, 07:27 PM
2012 MP4-12C
ZombiePhysicist's Avatar
If you live in warm weather it's going to be between the Michelin cup 2s and the Michelin 4S and likely the new PZeros (the old ones were crap).
If you live in an area where it gets cold, I think the 4S or the new PZeros.
The problem is we new the old PZeros and pirelli corsas were garbage in general, and that the Michelin Pilot Super Sport and Sport Cups were way better.
Since then Michelin has come out with the the 4S replacing the PSS and the 4S is better. However, the new PZero and corsas have also come out and are a LOT better, but its not clear how they stack up against one another.
I just got the 4S because I suspect they will do the best out of all those tires when it gets cold in NY. The old PSS were serviceable even in a little bit of light snow. Plus, the Michelins easily lasted over 20,000 miles including 4 track days.
But I don't know, I really want to see comparison done between the new MP4S, New PZero, New Corsa (and new Trofeo R and Cup2s if they exist).
TLDR, you want the MP4S if you're in cold weather area, or new PZero if you're in warmer weather. Both of those should fine in the wet.
ZombiePhysicist is online now
post #6 of 20 Old 05-13-2017, 07:28 PM
2012 MP4-12C
For track MPSC 2
Oh wow you got the new ones. Could you give your thoughts on them vs the cups?
post #7 of 20 Old 05-14-2017, 12:04 AM
enzom's Avatar
Curious - if you look at replacement tires on TireRack, you get a warning for the Trofeo R tires that reads: Rear: If fitting with P Zero Trofeo R use only 305/30-20 (99Y ) (2441400) labeled for use on the 650S, 625C, & 675LT. Use of P Zero Trofeo R 305/30-20 (103Y) (2271000) will result in vehicle damage!
What the heck could go wrong?
2016 650S Spider - Fire Black/Charcoal - 10.222 @ 138.29 stock!
2016 Cayenne Turbo S - Meteor Grey/Red & Black
2016 Tesla Model X - Silver/Charcoal
Gone -
2016 570S - Onyx Black/Saddle Tan - 10.275 @ 135.21 stock!
2016 Z07 - Shark Grey/Kalahari
2015 991 Turbo - GT Silver/Red & Black
enzom is offline
post #8 of 20 Old 05-14-2017, 12:26 AM
2012 MP4-12C
nordstat's Avatar
Slight difference in tire width. During hard cornering, the tire is pulled laterally away from the rim and can rub the diffuser causing cracking/damage. 15 mm spacers fix this issue.
nordstat is offline
post #9 of 20 Old 05-15-2017, 03:06 PM
Ado
I will get next week new tires for my 650 s. I decided to go with the new P Zero aimed for the 720s. They are 245 / 35 / R19 Front, 305 / 30 / R20 Rear. Maybe I need spacer because the front is 1 cm wider.
Ado is offline
post #10 of 20 Old 05-16-2017, 04:54 AM
2012 MP4-12C
nordstat's Avatar
From what others have said, the front is not the issue. Should be fine without spacers. The issue is rubbing of the rear diffuser. Most do spacers all around because it balances the look and makes the wheels flush with the wheel arches. To each their own.
nordstat is offline
post #11 of 20 Old 05-16-2017, 07:27 AM
Ado
Hmmh - at the rear both cars have the same tire width and the same rim width. How it is possible that the new Pzero is then wider? 99 or 103 is a load index and is not related to the width?? Somebody here to explain?
Ado is offline
post #12 of 20 Old 05-16-2017, 08:09 AM
isv
Tyres are not made equally wide despite the same quoted spec. A 305/30/20 can and will be different in width across different types of tyres. I can assure you that inflated the correct oem sized Michelin Supersport and Cup2s are physically wider than the mc spec Pirellis either pzero or corsa as well as the 99Y Trofeo. I'd be pretty surprised though if the 720 pzero rear would be very different from the older mc stamped Pirellis.
isv is offline
post #13 of 20 Old 05-16-2017, 08:16 AM
Ado
Maybe different across different manufacturer.
On mine 650s I can use 305/30/20 Pzero, Pzero Corsa and Pzero Trofeo - they should all be the same (in tolerance range). I suppose that old Pzero 305/30/20 and the new Pzero 305/30/20 will both be in equal size. Just imagine Pirelli have to explain to all buyers that you can`t use the new one because they are wider.
Ado is offline
post #14 of 20 Old 05-16-2017, 10:17 AM
enzom's Avatar
enzom is offline
post #15 of 20 Old 05-16-2017, 01:31 PM
Recent Convert
mikey k's Avatar
One of the UK guys ran cup2's on track and wore holes in the rear wheel arch liners. McLaren know about this and WILL NOT cover it under warranty.
I have MPSS on the rear of my 650 and it's never tracked. MUCH prefer them to the P Zeros. Especially for cold and wet roads.
MP4S wasn't available at the time, is it available now in the right size?
VR 650S Spider 14k miles done in 14 months!
mikey k is offline
